HBM
Torque transducers for quick application tests
HBM is launching the 'T40CB' torque transducer, which is particularly suitable for testing automotive parts in confined spaces thanks to its central bore.
According to the manufacturer, the compact model with a length of only 49 mm/ 54 mm and a central bore of 37.5 mm/ 46.5 mm diameter offers technicians the flexibility and ease of use required to perform application tests on automotive parts such as coaxial gearboxes or manual transmissions. The torque transducer uses HBM's 'T40' electronics, which offers an accuracy class of 0.05 and high linearity, ensuring accurate and reliable results. It also has analog and digital interfaces that ensure integration into many different test bench systems.
