Micro-Epsilon
Thermal imaging camera with spotfinder
The thermoImager TIM41 thermal imaging camera from Micro-Epsilon is robust and optimized for industrial applications. According to the manufacturer, it offers a high resolution and a wide temperature range from -20 to +900 °C for monitoring machines and systems.
© Micro Epsilon
The integrated spot finder function enables automated testing of hot and cold spots. Up to three measuring fields can be focused simultaneously and monitored continuously. Focusing can be carried out remotely via the integrated motorized focus. The measured values can be output to a controller, allowing further steps such as alarming, door opening, cooling or shutdown to be carried out if limit values are exceeded. The thermal imaging camera from Micro-Epsilon is commissioned using the 'TIM Connect' software included in the scope of delivery. Measured values can be output via Ethernet or process interface (4 - 20 mA). No additional PC is required for operation in stand-alone mode.
Micro-Epsilon
Confocal chromatic precision sensor
The confocal chromatic sensor 'IFS2407-1.5' expands Micro-Epsilon's 'confocalDT' sensor portfolio and is used for high-precision displacement and thickness measurement. The sensor has a measuring range of 1.5 mm with a base distance of 17 mm.
