Cross tables
Quelle: Physik Instrumente | Lukas Dehling,
Repeat accuracy of 0.1 µm
For areas such as industrial metrology and microscopy, optical inspection tasks and laser processing, Physik Instrumente (PI) offers a new series of differently motorized cross tables: V-731 and L-731.
© Physics instruments
They operate at speeds of up to 200 mm/s, with a bidirectional repeatability of 0.1 µm and a smallest increment of 0.02 µm. The 310 mm × 310 mm × 80 mm XY stages are available with travels of 205 mm × 205 mm mm (8 inches), whereby customer-specific adaptations are also possible. They are controlled via PI controllers or - in multi-axis portal applications - via an industrial control system from ASC. The new cross tables are driven by linear drives (V-731) or stepper or DC motors (L-731). The three-phase linear motors dispense with mechanical components in the drive train and transmit the drive force directly to the motion platform without friction. This enables speeds of up to 200 mm/s. According to the manufacturer, the ironless motors are particularly suitable for positioning tasks with high precision requirements, as there are no undesirable interactions with the permanent magnets. The L-731 cross table operates at speeds of up to 80 mm/s. Either stepper or DC motor spindle drives can be used as the drive.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
