Jumo
Optimized climate monitoring
Devices in the 'Hydrotrans' series from Jumo are humidity and temperature transmitters with an optional CO2 module. The device series is suitable for climate monitoring in offices and living spaces, railroad applications, storage rooms or production halls.
The moisture meter series from Jumo is available with different interfaces and four variants are available - as wall, duct, rod or room versions. The different versions with protection classes between IP20 and IP65 make the device suitable for a wide range of applications. The measuring range covers 0 to 100 % RH, the accuracy is 2 % RH at +23 °C. The measuring device has a color display and can be used in temperature ranges from -40 to +80 °C. The optionalCO2 module can be used to precisely determine the air quality. A voltage and current output as well as Modbus are available as interfaces. In addition, the Single Pair Ethernet (SPE) interface with PoDL enables a simplified cloud connection and continuous Ethernet communication from the field to the automation level.
