Products of the year 2023
Measurement technology - The winners
Whether it's heat, pressure or flow, measurement technology allows the system operator to keep an eye on everything. The winning products in the 'Measurement technology' category show which measuring principles can help with this.
3rd place - Micro-Epsilon
The compact thermoIMAGER TIM41 thermal imaging camera from Micro-Epsilon is robust and optimized for industrial applications. According to the manufacturer, it offers a high resolution and a large temperature range of -20 to +900 °C for monitoring machines and systems. The integrated spot finder function enables automated testing of hot and cold spots. Up to three measuring fields can be focused simultaneously and monitored continuously. More...
Manfred Pfadt, Product Manager / Group Leader Sales Sensors at Micro-Epsilon, lists the most outstanding features of the thermal imaging camera. He also provides insights into further planning for the coming 12 months.
2nd place in the measurement technology category
2nd place - Teledyne Flir
Teledyne Flir expands the Si124 series of industrial acoustic cameras. The revised Si124 and the Si124-PD models for partial discharge testing in power supply applications and Si124-LD for air leak detection have an acoustic imaging range of 2 to 65 kHz. Thanks to the ability to detect noise in the extended frequency range of 36 to 65 kHz, even very small leaks and discharges can be detected at short distances in condition-based maintenance. More...
Andreas Föll, Team Lead CM Central Europe at Teledyne Flir, knows all there is to know about the noises in a system. In this interview, he provides insights into how sound can be used to detect leaks or malfunctions.
1st place in the measurement technology category
1st place - Jumo
Jumo's programmable pressure transmitter Jumo Siras P21 AR/DP is approved for use in safety-related systems with Safety Integrity Level (SIL) in accordance with DIN EN 61508 and Performance Level (PL) in accordance with DIN EN 13849, making it suitable for safety measuring chains in the process industry and suitable for a wide range of applications. It measures the relative, absolute or differential pressure of liquids, vapors and gases. More...
In conversation with Matthias Halsch, Product Manager Printing at Jumo, the focus was not only on the technical details of the pressure transmitter but also on the team. The award, which will be presented as a challenge cup to all departments involved in the development, comes just in time.
