Carlo GavazziPrecise control of infrared heaters
In order to support manufacturing companies that use industrial heating applications in their orientation towards Industry 4.0, systems that can precisely switch these special heating loads and also take over the complete monitoring of the load circuit are helpful.
<p>The NRG system consists of a control unit and several solid state relays. The control unit acts as a gateway for a subsystem with a maximum of 32 solid-state relays and as a master via which each individual solid-state relay in the chain can be controlled and switched on or off via the internal bus.</p>
© Carlo Gavazzi
