Carlo GavazziPrecise control of infrared heaters
In order to support manufacturing companies that use industrial heating applications in their orientation towards Industry 4.0, systems that can precisely switch these special heating loads and also take over the complete monitoring of the load circuit are helpful.
<p>The control unit with a width of 35 mm is equipped with two RJ45 ports for the PLC-side interface, an RCRGN cable connection for the internal bus and a 24 VDC supply connection. LEDs indicate the device status: the supply voltage to the control unit and errors in the communication connections.</p>
© Carlo Gavazzi
