AlthenDetermined by DMS
In a material test, the properties and structures of a material are determined in the form of parameters using various physical or chemical tests and measurements. Reliable helpers in this process: strain gauges.
<p>Shear test to ASTM D7078 using a rail shear test fixture with a V-shaped notched specimen in which a strain gauge rosette with a measuring grid length of 10 mm is used. The aim of the test is to determine the shear properties (shear modulus, shear strength and maximum shear strain).</p> © Grasse Zur Engineering Company
