Data logger
Quelle: Ahlborn Mess- und Regelungstechnik | Lukas Dehling,
Connect any sensors
The Almemo 710 data logger from Ahlborn offers ten galvanically isolated measurement inputs. Sensors for any measured variables can be connected and evaluated. This applies to sensors from the manufacturer as well as to existing sensors from any other manufacturer.
© Ahlborn measurement and control technology
A large graphic display shows measured values and functions in the best possible way and is operated via a touchscreen. According to the manufacturer, the menu navigation is simple and clearly structured: Measurement, peak, average and limit values can be displayed in lists, bar charts and line graphs. Users can even configure their own menu to display the parameters required for their application. For evaluation on a PC, the measurement data is stored in an 8 MByte flash memory, which can also be activated as a ring memory. If the memory space becomes too small with a measuring speed of up to 1000 measurements per second or autonomous long-term recording in sleep mode, external memory with a MicroSD card can simply be plugged in. In addition, the measuring device is now equipped with a new connector type with integrated A/D converter and serial interface. The advantages of this Almemo D7 connector are the digitized sensor signals, any length of connection cable and the simple replacement of defective, calibrated sensors.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
