Micro-Epsilon
Complete 3D solution with standardized software
Micro-Epsilon's '3DInspect' software enables the parameterization and acquisition of measurement data from the new generations of the 3D product portfolio for precise geometry, form and surface inspection - Surfacecontrol, Reflectcontrol and Scancontrol.
© Micro-Epsilon
The software's range of tools extends from the alignment of point clouds and calculation programs for distance, height, angle and radius to simple output options to the PLC and subsequent further processing of the measurement data. In addition to the standard version, the 'Automation' function extension is available for automated production processes.
The 3D software package is compatible with the 'Surfacecontrol' 3D sensors, which are used for fast 3D measurement and inspection of diffusely reflective surfaces such as metal, plastic or ceramic. The 'Reflectcontrol' sensor is used for 3D measurements on reflective and shiny surfaces. The software is also compatible with laser scanners from the 'Scancontrol' series.
Micro-Epsilon at the Hannover Messe 2023: Hall 9, Stand D05
Hannover Messe 2023
Climate-friendly production
After a scaled-down version in 2022, the largest industrial trade fair wants to return to its full format this year. Many of the exhibition topics are not new - but from the organizers' point of view, their discussion is now all the more urgent in...
Micro-Epsilon
Confocal chromatic precision sensor
The confocal chromatic sensor 'IFS2407-1.5' expands Micro-Epsilon's 'confocalDT' sensor portfolio and is used for high-precision displacement and thickness measurement. The sensor has a measuring range of 1.5 mm with a base distance of 17 mm.
