Switch cabinets
Quelle: Eplan Software & Service | Lukas Dehling,
Visualize the wiring
With Smart Wiring Application, Eplan is presenting software that visualizes the wiring and provides data for production in digital form, such as source/destination description, connection point designation, cross-section, color, wire length, final treatment or exact installation paths.
© Eplan Software & Service
This eliminates the need for time-consuming and error-prone wiring based on the circuit diagram. The digital representation references the 3D layout of the virtual model in Eplan Pro Panel. However, the new application can also be used without a 3D layout: For example, Excel lists with connection information can be read in. A menu describes each connection; this information is supplemented by the visualization of the equipment including connection points and the planned routing paths of the wires in the control cabinet. The software provides information on the required diameter of a wire, the color to be used and the defined final treatment - crimped or ultrasonically welded, for example. It also indicates whether a wire belongs to a bundle.
Rittal
Switch cabinet becomes a refrigerator
Rittal presented the prototype of a new integration solution for enclosures and cooling solutions at the recent SPS IPC Drives trade fair. In future, the time-consuming assembly of cooling units on side and roof areas will be almost completely...
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
