Batch software
Quelle: Rockwell Automation | Lukas Dehling,
Supports mobile devices
The latest version of Rockwell Automation's Factorytalk batch software promises improved operation through a modern web-based interface.
© Rockwell Automation
At the same time, it should be more scalable and offer responsive phase sequences of distributed process skids, centrally coordinated at the production level. By integrating with Rockwell Automation's SequenceManager solution, sequencing is controlled at either the controller or server level. This enables machine builders to develop fully tested skids that end customers can integrate into their batch processes with minimal validation effort and short commissioning times. It should also reduce the amount of rework required when manufacturers with small, controller-based batch systems want to upgrade to larger server-based batch systems. The new web-based interface can help to create intuitive workflows, reduce process steps and improve collaboration. With mobile devices, employees no longer need to be directly connected to the control center and fixed terminals. They can access information in real time, interact with processes and obtain production approvals plant-wide. It should also reduce the number of clicks previously required to access information.
Siemens
New management for Group strategy
Peter Körte will be the new Head of the Siemens Strategy Department from February 1, 2020. He replaces Horst J. Kayser, who has been responsible for the Siemens Portfolio Companies since the beginning of January and has continued to manage the...
Photonics Software
Keysight Acquires VPIphotonics
With the acquisition of VPIphotonics, Keysight Technologies is expanding its software portfolio for photonics development. Going forward, these solutions will cover the entire design process, from component physics to the simulation of complete...
