Phoenix Contact
Software for switch cabinet construction
The engineering software clipx Engineer from Phoenix Contact makes it possible to plan and order terminal strips, assembled mounting plates and terminal boxes and seamlessly transfer the data to production.
© Phoenix Contact
Thanks to the online and offline application, the planning can be accessed from any work location. You can choose to work on the project locally on your computer or share it via a cloud. The bidirectional interfaces to CAE programs and the direct connection to Phoenix Contact applications, configurators and the online store speed up time-consuming planning tasks. Engineering assistants simplify planning. Entire function groups can be created with just a few clicks or articles can be checked for application-relevant approvals.
In addition, the planning is automatically completed with the necessary accessories. Generated production documents are used for documentation and subsequent process steps.
Phoenix Contact
Securely wired and plugged in
When developing the M12 push-pull quick connector in accordance with IEC 61076-2-010, the aim was to retain proven features and add innovative ones. As a result, the familiar features of the M12 connector are combined with the functions of push-pull...
Wibu-Systems
Protection for intellectual property
In the industrial environment, extensive data input is generated from a wide variety of sources, which is often processed with the help of artificial intelligence applications. How can the good ideas behind this process be effectively protected?
Industry 4.0
The top dialog
The future-oriented Industry 4.0 project was officially launched at Hannover Messe 2011. The Industry 4.0 platform's research advisory board has now met for a top-level dialog and drafted a twelve-point communiqué on the work still to be done.
