Mathworks
Meinrad Happacher,
From a fashionable topic to reality
Artificial intelligence and machine learning are the hot topics in the Industry 4.0 environment - but what can already be implemented in practice today? Philipp Wallner, Industry Manager at Mathworks, takes a stand.
Philipp Wallner: "Getting machine learning algorithms onto target systems such as a PLC is still a problem in many cases!"
© Computers&AUTOMATION
Mr. Wallner, artificial intelligence and machine learning are buzzwords that adorn the hype surrounding Industry 4.0. What do these terms have to offer apart from nice-sounding messages?
Philipp Wallner: Of course, I can only speak for our company MathWorks and our customers. But our customers from the mechanical and plant engineering sector are now very much looking at what can be put into practice in terms of Industry 4.0. Two areas of application that the industry is looking at extensively today are virtual commissioning based on model-based development and predictive maintenance based on machine data using artificial intelligence methods.
While conventional methods for virtual commissioning are aimed exclusively at using a model of the machine - i.e. a 'virtual machine' - to test the programs that will later be executed on an industrial control system in advance, model-based development goes one step further. Both the machine and the controller - i.e. the functionality that will later run on the controller - are implemented in the model and used throughout the entire development cycle for simulation, verification and automatic code generation. This means that the cost of creating the model is significantly lower than with traditional virtual commissioning.
And the models from the simulation then also serve as the starting point for the digital twin of the system?
Philipp Wallner: Correct. Algorithms that combine both domain expertise in the form of models and artificial intelligence technologies - such as machine learning or deep learning - have proven to be particularly effective for predictive maintenance, but also for other areas such as optimizing plant performance or energy consumption.
Keyword 'artificial intelligence' - where do you still see the biggest challenges?
Philipp Wallner: Firstly, there is the lack of sufficient error data. If you don't allow components, machines and systems to fail during operation, there is naturally no or very little fault data. However, this is absolutely essential in order to train the algorithm accordingly. Simulation models provide a remedy here by simulating different fault scenarios and thus generating synthetic fault data.
The second challenge that we often see is that machine learning algorithms are developed in special data science environments that do not offer any options for implementing the algorithms on corresponding target systems such as a PLC or an edge system. We will show how this is implemented with Matlab using a demo with industrial hardware at our stand.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
