Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a few 100 W.
Torsten Blankenburg, Sieb & Meyer: „Our goal is to drive high-speed motors dynamically and with as little power dissipation as possible“.
© Sieb&Meyer
The SD4S is the first member of the SD4x frequency inverter family from Sieb & Meyer.
© Sieb&Meyer
The new frequency inverters support interfaces and protocols such as Profinet, TNC or BiSS. Their central feature is the significantly improved processor performance: The built-in 32-bit ARM Cortex M7 processor from NXP is up to five times faster than the processors of the SD2x frequency inverters, thus allowing higher resolution and more accurate calculations. In addition, Sieb & Meyer has switched from fixed-point math to floating point math, allowing a more flexible design. „Overall, more complex tasks can be processed more quickly with the new processor system,“ says Torsten Blankenburg, Chief Technology Officer at Sieb & Meyer. In addition, a new FPGA from Xilinx‘s „Spartan-7“ product line has been integrated: It enables more complex control tasks to be processed. Sieb & Meyer has also significantly increased its memory capacity compared to the members of the SD2x family - „with the 500 times larger memory, there will be no bottlenecks in the foreseeable future,“ says Blankenburg. „For the customer, this means a significant increase in performance: higher switching frequencies and improved control quality at even higher speeds lead to improvements in the overall process.
Thanks to an integrated position controller, the SD4x devices can also perform independent, high-precision positioning; speed and current controllers remain constant compared to the SD2x series. „Our aim is to drive high-speed motors dynamically and with as little power dissipation as possible,“ explains Blankenburg. „That‘s why we now also support PWM switching frequencies of 24 and 32 kHz.“ For even finer modulation of the sinusoidal signal, a commutation angle control is now also integrated for 32, 48 and 64 kHz. „This results in an almost optimal sine wave and virtually no harmonic currents,“ notes Blankenburg.
The new „drivemaster4“ version of Sieb & Meyer‘s parameterization software offers a four-part user interface. A watch list makes it possible to subscribe to the parameters of several devices simultaneously - „this is particularly useful for multi-axis applications“, as Blankenburg explains. Users can also use a data logger to view and evaluate characteristic curves over longer periods of time.
The SD4S is designed for small high-speed spindles and motors with a power range of just a few 100 W. Examples of applications are dental milling machines or machines for precision machining, such as those required in the watch industry. Because small spindles often do not have the necessary insulation strength in the motors, the SD4S now enables galvanic isolation of the thermal contact. Blankenburg regards the width of only 40 mm as an „absolute novelty“.  The SD4S is designed for use in a wide range of applications.
The parameters are set via a standard Ethernet interface, which replaces the USB interface, which is prone to failure in industry. In addition, the SD4S has parameterizable digital measuring system interfaces such as BiSS-C, EnDat2.2 and TTL. A web server enables technicians to call up device information without additional parameterization software. An incident can be synchronized via the real-time clock: For example, users can find out whether a thunderstorm has caused a failure.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
Vega
Radar for the price of ultrasound
Compared to ultrasound, radar measurement technology offers various advantages, but is significantly more expensive to date. Vega is now launching a new series of instruments that eliminates this cost disadvantage.
