Siemens
Andrea Gillhuber,
AI-based service edge app for drives
Siemens is expanding its 'Predictive Services for Drive Systems' offering with the Predictive Service Analyzer edge app.
© Siemens
The AI-based solution already recognizes the first signs of anomalies that indicate mechanical damage in the motor, such as bearing damage, imbalance and misalignment, as well as critical operating conditions of the inverter. The app assesses the severity of the defect and the expected remaining running time and can therefore predict any future failures. The Service Edge app is particularly suitable for applications with constant movements, e.g. pumps, fans and compressors or motors that do not require speed control. In contrast to the MindSphere App Predicitve Service Assistant, which has already been launched on the market, the analysis of the Edge App is based on the evaluation of very large amounts of data in near real time. The edge-based solution is also used for secure data handling in the plant and reduces costs for cloud data transfers.
Siemens
More advantages in the package
Industrial production only becomes flexible and efficient through data transparency and the intelligent use of data. This means that more and more data needs to be collected and evaluated. Effective interaction between software and hardware is...
Siemens
The Siemens App Store
Siemens is now opening a digital, cross-manufacturer app store for industrial customers. The marketplace forms the transaction mechanism specifically for the Siemens Industrial Edge platform.
Siemens
Visualization overcomes boundaries
Until now, the worlds of operation and monitoring were separate: here machine-oriented operation, there plant-wide monitoring. Modern visualization systems act as a gateway from OT to the IT world, enabling a consistent solution for HMI and SCADA...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
