Display Visions
Show process data on several displays
With the 'Core' PLC product family from Display Visions, process data can be shown on several displays or settings can be made via these displays.
The focus of the small controller from Display Visions is on the IPS displays and their automatic networking. The controller itself is designed as a top-hat rail PLC and has a 2.8-inch IPS display including a touch panel to clearly display all key parameters on site. Up to 50 so-called satellite displays communicate directly with the control system - via RS485, LAN or WLAN/WiFi. All process parameters are automatically synchronized with each other. This means that one display can visualize the most important data as a monitor at any location, while another display allows inputs for various parameters, for example. Satellites are available in display sizes 1.5, 2, 2.8, 3.5, 4.3, 5, 7 and 10.1 inches. The displays are easy to read with an all-round viewing angle of around 160°. At just under 1000 cd/m², they are suitable for use in sunlight.
