Numcad / IntervalZero
Purely software-based CNC control
According to Numcad, CNC64 is the first purely software-based real-time control for CNC machines. It is based on the real-time extension RTX64 (Real Time eXtensions for Windows) from IntervalZero, which transforms Windows into a real-time operating system.
CNC machines can now be controlled in real time with the CNC64 control software from Numcad.
© Numcad/IntervalZero
The CNC64 software enables the control of machines and robots. It uses G-code in accordance with DIN 66025 and supports CAM-generated files. Users can flexibly customize the HMI interface with the integrated designer for each machine, whereby the setup of different user profiles (from operator to administrator) is possible.
Mathematical models help to increase the accuracy and speed of the CNC machine's motion calculations. Because the CNC64 system consists entirely of component-based software, users are free to decide which hardware (motors, I/Os, etc.) they want to use. The open design also allows customers to add their own functions such as image processing using the C/C++ programming language in a deterministic environment.
The concept behind this flexibility is to use standardized software components and interfaces based on RTX64 to transform any Windows 10 industrial PC into a high-performance real-time machine with 64 bit and multicore support with up to 128 GB memory. Numcad chose EtherCAT as the industrial Ethernet standard because many different companies offer EtherCAT systems and components from which customers can choose what they need. The image processing technology can be connected via Gigabit Ethernet interfaces according to the GigE Vision standard in conjunction with a deterministic solution for the actual image processing. The fully integrated soft PLC with OPC UA support works according to the IEC 61131-3 standard and is the real-time engine that ensures the smooth cooperation of all components.
Numcad also offers support for customers who want to port the system to their own environment. "With the CNC64 system, existing production processes can be renewed without losing the 'lifetime cycle guarantee' for the old control hardware," said Numcad. "Shorter process cycles thanks to modern hardware conversion also reduce production costs."
The RTX64 real-time extension for Windows is characterized by 64-bit addressing. "Real-time applications running on a 64-bit Windows 10 with RTX64 can use up to 128 GB of non-paged memory, depending on the actual RAM memory available," explains Bernhard Hartmann, Sales Manager Central Europe at IntervalZero. "The now directly addressable real-time memory in Windows and the resulting performance distinguishes the RTX64 solution from virtualization alternatives and real-time solutions based on an old 32-bit operating system."
Thanks to the CNC64 software solution, the required components are completely integrated in one and the same industrial PC. The components include HMI, soft PLC, EtherCAT system, high-end CNC kernel (optionally with kinematic transformation, multi-channels and gantry, among other things) and material removal with machine simulation to avoid collisions.
Machine tools
Okuma buys Hommel CNC Technik
Okuma Europe and Hommel Holding have signed a purchase agreement for the acquisition of Hommel CNC Technik. With the takeover of the long-standing German sales partner, Okuma intends to consolidate its position in Europe's largest market for machine...
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
