Sortienus
NC programming systems extensively expanded
Quadro NC is a 2½-D system for external NC programming of all common CNC controls for lathes, milling machines and machining centers.
© Sortienus
In the new version 10.2 for Windows 10 of Sortienus, the options for contour input have now been expanded, among other things. Previously, NC programs could either be created in the editor or defined using geometry elements such as points, circles and lines. Now the geometry kernel also allows fast, direct geometry input. With a graphic simulation on the screen, finished NC programs are checked in the programming system before they are sent to the turning and milling machines. This makes it possible, for example, to ensure error-free machining with existing NC codes. A function has now been added to QuadroNC: After re-simulation of an existing NC program, the original geometry can be generated and output again. In this way, the geometry file can be used as the basis for variants or new components.
Further possibilities - from simple visualization to further processing in the CAD system - are opened up by output as a DXF graphics file.
Zimmer Group
Robots automate machine tools
In order to increase productivity in production, more and more companies are deciding to interlink and automate their machine tools. The right automation system is crucial. Robots and the right gripping technology play an important role here.
Tech Mahindra
Implement 5G now!
Should the factory data be stored in the cloud or rather on site in your own data center? The next generation of mobile communications should be taken into account in these considerations. After all, 5G can make a decisive contribution to the...
Calnex Solutions
Time synchronization
Time synchronization via Ethernet and IP networks is the basis of many systems worldwide. This is why the IEEE defined the 1588 Precision Time Protocol (PTP) and time standardization bodies such as the ITU-T created supporting standards for function...
IoT Hotspot
Focus on cloud and edge computing
The Eclipse Foundation, currently the largest open source organization in Europe, wants to promote global industry collaboration on open source projects in strategic technologies. Mike Milinkovich, Executive Director of the Eclipse Foundation,...
