Controller
Quelle: Wago Kontakttechnik | Inka Krischke,
Can also be used as a secure gateway
The PFC100 and PFC200 controllers from Wago encode data in the controller using SSL/TLS 1.2 and transfer it securely to higher-level systems via a VPN tunnel.
© Wago contact technology
The devices offer a cross-platform real-time Linux, which, as an open source operating system, is long-term available, scalable and update-capable and supports tools such as Rsync. Accordingly, they can also be used as a secure gateway. Interfaces and fieldbuses such as CANopen, Profibus DP, Devicenet and Modbus-TCP can be operated independently of the manufacturer. In addition, the PFC200 family is set up to implement security requirements in accordance with the ISO 27000 series. It offers onboard VPN functionality based on the so-called 'Strongswan Package' and the OpenVPN package. In addition, the data can already be encoded in the controller using SSL/TLS 1.2 encryption. It then establishes a VPN tunnel directly via IPsec or OpenVPN and, if desired, also transmits the data wirelessly to the cloud. While IPsec encrypts at operating system level or layer 3, OpenVPN ensures data integrity at application level (layer 5). This creates tap-proof and tamper-proof communication connections between the controllers and the network access points. An upstream VPN router is no longer required.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
