Kunbus
IPC based on the Raspberry Pi
Revolution Pi is an open, modular industrial PC from Kunbus based on the Raspberry Pi. Housed in a slim top-hat rail housing, the three available basic modules can be expanded with a variety of suitable I/O modules and fieldbus gateways.
The 'Revolution Pi' industrial PC from Kunbus
© Kunbus
The modules, which are operated with 24 V, are connected to each other via a top-mounted plug connection and can be configured using a graphical configuration tool. In order to achieve industrial suitability in accordance with EN 61131-2 or IEC 61131-2, the Raspberry Pi Compute Module was used as the basis. According to Kunbus, the module, which looks similar to a notebook RAM bar, is limited to the essentials and does not have any external interfaces.
The Raspberry Pi Compute Module provides the basis for equipping the Raspberry Pi with robust and industrial-grade peripherals that meet all important industrial standards. On the software side, the IPC has a specially adapted Raspbian operating system, which has been equipped with a real-time patch, among other things.
Kunbus at the SPS 2021
Alternative to PLCs
The RevPi Connect+ feat.Codesys from Kunbus can be used as a modular and powerful small controller for a variety of different automation tasks and, according to the provider, represents an alternative to complex and cost-intensive PLCs.
Kunbus
UL certification received
Kunbus has received UL certification for its open source IIoT gateways RevPi Connect. This means that all base modules in the 'Revolution Pi' family are now approved in accordance with UL standards.
