Subrack
Quelle: Polyrack Tech-Group | Inka Krischke,
Individually customizable
The robust Future subrack series from Polyrack can be customized and is designed for different shielding concepts and applications in harsh environments.
© Polyrack Tech-Group
Thanks to the double bolting of the sturdy profiles and the toxed version of the side panels, the series meets the requirements for a 'vibration-resistant' product and therefore qualifies for use by Deutsche Bahn (in accordance with LES-DB) and the French railroad system (NF-F). Depending on the requirements profile, various configurations can be put together using the standard parts of the series. The basic designs differ in terms of vibration resistance and shielding concept: in the 'EMC spring' shielding concept, the corner brackets have a groove for clipping in spring elements; in the 'EMC seal' concept, they have a leg for gluing in a CuNi-coated fabric. There is also an IEEE 1101.1/IEEE 1101.10-compliant version with front profiles and grid perforation. Combinations of positive-locking and double-bolted side panel corner brackets and side panel end panels ensure a robust structure. The profile positioning in a 10 mm grid also enables dual expansion.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
