Raspberry Pi solutions
Quelle: Mass | Lukas Dehling,
In protection class IP54
The credit card-sized Raspberry Pi 3B from Mass is housed in a metal casing. The mini PC contains the ARM Cortex-A53 processor with 4× 1.2 GHz clock frequency, plus 1 GB RAM, a micro SD card (8 GB or larger) for the operating system and application software as well as ...
© Mass
... the interfaces 4× USB2.0 and 10/100 Ethernet, which are routed to the outside. The board also has connections for HDMI, CSI camera, video/audio and post connectors for RS232, CAN, I²C or 8 GPIO, for example. Various additional functions and interfaces are included on an expansion board (real-time clock, battery, CAN module, RS232/485, DIO, analog I/O etc.) as well as a 12 or 24 V (DC) industrial power supply unit. The system has been designed for high reliability in harsh industrial environments. The desired operating system is installed on the micro SD card. The housing has IP54 protection and is supplied with mounting brackets or brackets for 35 mm mounting rails. The dimensions are 39.7 mm x 144 mm x 106 mm (H×W×D).
Mass
Large display included
Mass offers industrial computers with a large display, which are arranged in front panels as PPCs (panel PCs) or free-standing as SACs (stand-alone computers).
Raspberry Pi
Arriving in the PLC world
The Raspberry Pi is being used more and more in industrial electronics applications and has now arrived in the world of PLC systems: Mass presents the new RPi07-Xtend development as a first expansion stage.
Mini computer
Raspberry Pi - fit for automation
The Raspberry Pi computer is enjoying great popularity - and not just in the hobbyist scene. That's why more and more automation companies are turning to the open source computer, as Computer&AUTOMATION shows in the following series of images.
