Boards
Quelle: Spectra | Lukas Dehling,
Expand thanks to riser card
Spectra is offering a new mini-ITX board series with the latest Intel Apollo Lake processors (N4200/N3350) and one PCI slot. The LV-67U series can be expanded to two PCI slots by using an additional riser card.
© Spectra
This means that users can continue to use the tried-and-tested PCI cards and benefit from the latest processor technology. According to the company, this means that larger amounts of data can be processed faster. Operation under Windows 10 is also possible. In addition, six serial COM interfaces, two of which are isolated, and a wide-range voltage input of 9 - 24 VDC provide the prerequisites for industrial use.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
