Peak system
Data exchange via CAN FD
The I/O module PCAN-MicroMod FD from Peak-System is now also available with ready-made motherboards in a black aluminum profile housing in addition to its use as a plug-in module in in-house developments.
Data exchange via CAN FD.
© Peak system
The directly usable devices exchange data via CAN FD, which is downwards compatible with classic CAN 2.0. Various motherboards contain either analog inputs or digital outputs. All motherboards have an analog input for voltage monitoring up to 30 V and two additional frequency outputs up to 20 kHz in common.
The motherboards are configured with PCAN-MicroMod FD using the supplied Windows software and transmitted via CAN. According to Peak-System, the motherboards then run as independent CAN nodes. The devices are wired via spring terminal connectors. They can be operated in an extended temperature range between -40 and +85 °C.
You will find Peak-System in Hall 1, Stand 483
© NurembergFair
esd electronics
Migration to CAN FD
In 2011, work began to push the existing limits of classic CAN in terms of the maximum achievable data rate - the idea of CAN FD was born. But is it really worth migrating to CAN FD now?
E.E.P.D.
Industrial NUC box
The 'New Unit of Computing' (NUC) is an invention by Intel. E.E.P.D has made the form factor suitable for industrial use and installs processors from the 'AMD Ryzen Embedded V1000' platform in it.
PLCopen
The CPU benchmark
PLCopen is currently working with Intel, AMD and ARM on a CPU benchmark. Eelco van der Wal, Managing Director of PLCopen, explains the background to this.
