Phoenix Contact at SPS Connect
Inka Krischke | Tiffany Dinges,
Can also be operated with thick gloves
With its all-in-one solutions (AIO), Phoenix Contact offers industrial PCs with a fully enclosed die-cast aluminum housing (IP65) that can be expanded modularly and integrate Profisafe functions.
© Phoenix Contact
The current sensor generation allows the screen to be operated even when wearing thick gloves. The glass front increases the robustness of the capacitive technology with regard to aggressive cleaning agents and sharp objects. Displays in sizes 15.6, 18.5 and 21.5 inches with full HD resolution enable the visualization of everything from simple procedures to complex production processes, with details being displayed using gesture control.
The AIO devices include Intel Core i5 processors so that they can also implement resource-demanding tasks such as machine control, process visualization or quality assurance. According to the provider, the VESA 100 hole size on the rear of the housing allows mounting directly on the machine or system. Installation on a support arm or stand is also possible with the matching back cover. On request, the industrial PCs can be supplemented with up to eleven buttons or switches via a button module, which can be assigned USB ports, key switches or other functions.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Phoenix Contact
M12 with push-pull locking
Phoenix Contact is expanding its portfolio of M12 connectors with push-pull quick locking and is making the A-, D- and L-coded device connectors with pin contacts available with the matching push-pull housing screw connections for SMD and THR...
Phoenix Contact
System availability ensured
Even if only one component fails, the entire machine or system can - in the worst case - come to a standstill, as their functions are usually closely interlinked. To prevent this worst-case scenario, every fault must be safely shut down.
Phoenix Contact
The 'security life cycle'
In the European Economic Area, the requirements of the Machinery Directive apply to manufacturers of machinery. Their specifications must be complied with before a machine is placed on the market. Many safety regulations must already be observed...
