Phoenix Contact
Extended to include fiber optic variants
Phoenix Contact is expanding the FL Switch 1000 series with fibre optic variants that are housed in a slimline enclosure and, according to the supplier, offer a higher port density and prioritization of data traffic for automation protocols.
© Phoenix Contact
The seven models include both Gigabit and Fast Ethernet variants, enabling applications with different bandwidths in a variety of industries. Some devices are also equipped with SFP ports, providing greater flexibility for customers depending on their connection type and distance requirements.
With the mounting accessories, the switch series can be mounted flat on the mounting rail, enabling use in small or flat cabinets with limited space.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Phoenix Contact
M12 with push-pull locking
Phoenix Contact is expanding its portfolio of M12 connectors with push-pull quick locking and is making the A-, D- and L-coded device connectors with pin contacts available with the matching push-pull housing screw connections for SMD and THR...
Phoenix Contact
System availability ensured
Even if only one component fails, the entire machine or system can - in the worst case - come to a standstill, as their functions are usually closely interlinked. To prevent this worst-case scenario, every fault must be safely shut down.
