ICP Germany
Andrea Gillhuber,
SPE switch for cost-efficient cabling
Single Pair Ethernet (SPE) is making its way into the ICP Germany portfolio. The 'ITPS-141TX' is a 5-port unmanaged SPE switch.
© ICP Germany
The unmanaged SPE switch is compatible with IEEE 802.3cg and enables point-to-point data transmission over a distance of up to one kilometer. It also supports IEEE 802.3bu, Power over Data (SCCP PoDL), with which the switch can provide up to 50 W per port in force mode to power sensors and other devices.
The ITPS-141TX offers a total of four 10Base-T1L ports with PoDL and one 10/100 Base-T(X) RJ45 port and measures 28 mm × 108 mm × 145 mm with its IP30 housing. With a voltage input of 20~30 VDC and an operating temperature range of -40 to +70 °C, the PLC switch is suitable for industrial use.
Most read
The top articles in July 2024
Innovative spirit and entrepreneurial thinking characterize the most-read articles from July. Find out more about competitive advantages through AI, click through award-winning developments and read more about model-based design and quantum sensor...
