Vision Components
Image pre-processing integrated
All VC MIPI Cameras of Vision Components are now available with a VC Power SoC integrated into the design of the tiny modules, which enables image pre-processing directly on the MIPI module.
© Vision Components
Vision Components is thus continuing the series of VC Power SoM FPGA accelerators: until now, the VC Power SoM could be integrated directly in the MIPI data stream as a component in the design of a base board or on an adapter board. With the VC Power SoC, this functionality is now a direct component of the camera module. The tiny form factor of the cameras remains unchanged: the FPGA accelerator is simply attached to the back of the camera module. Compared to the original VC Power SoM, the SoC version has fewer logic cells, but offers sufficient performance for many applications with the smallest possible space and cost consumption. VC is also expanding the range of FPGA accelerators with the even more cost-effective VC Power SoM light.
IDS at the SPS 2024
Precise Even in Motion
IDS is participating in the SPS for the first time, with a focus on industrial image processing for robotics, process automation, and connected systems. One of the highlights at their booth is a ToF (Time-of-Flight) camera. Patrick Schick, Product...
MVTec
Dynamic OCR Inspection
Due to strict compliance regulations, packaging containing medical products must be correctly labeled before it is delivered to customers. The Chinese company Shenzhen Jiangrun Xuneng Technology has developed a sophisticated image processing...
