autoVimation
Inka Krischke | Tiffany Dinges,
Precisely align the protective housing
The positioning system is a compact solution for the precise alignment of protective camera housings. The core of the modular system consists of fine positioning axes with 150 mm stroke, which ensure high adjustment accuracy with their hand-cranked feed rate of 1.5 mm/revolution.
© autoVimation
According to the supplier, the axes are slimmer than conventional models, as their spindle channel with dovetail profile also serves as a sliding guide for the slides.
For free positioning of the cameras at any angle, the accessories of profile rails, rotary axes, angles and interchangeable positioning tables for vertical or axis-parallel mounting enable multi-axis arrangements to be set up quickly. No adapter plates are required for this, as all of the manufacturer's components use standardized profile systems - camera housings or additional axes can be mounted directly to the positioning tables using dovetail clamps.
with dovetail clamps.
VMT
Dynamic visual guidance for 6-axis robots
As part of the production ramp-up for the Audi model derivatives of the A3 successor at the Ingolstadt plant, an automated system for the application of primary seals in vehicle doors was put into operation together with the image processing system...
Isra Vision
Guided by the point cloud
In assembly processes, 3D point cloud technology plays a special role in the guidance of industrial robots. Quad-camera sensor solutions that enable multi-stereo recordings are a new approach here.
SVS-Vistek
Machine Vision streamlined
In order to generate the required amount of light for high-quality images, image processing systems usually work with external flash controllers. A current approach integrates these control units into the camera, thus reducing effort and costs for...
