autoVimation
Precisely align the protective housing
The positioning system is a compact solution for the precise alignment of protective camera housings. The core of the modular system consists of fine positioning axes with 150 mm stroke, which ensure high adjustment accuracy with their hand-cranked feed rate of 1.5 mm/revolution.
According to the supplier, the axes are slimmer than conventional models, as their spindle channel with dovetail profile also serves as a sliding guide for the slides.
For free positioning of the cameras at any angle, the accessories of profile rails, rotary axes, angles and interchangeable positioning tables for vertical or axis-parallel mounting enable multi-axis arrangements to be set up quickly. No adapter plates are required for this, as all of the manufacturer's components use standardized profile systems - camera housings or additional axes can be mounted directly to the positioning tables using dovetail clamps.
with dovetail clamps.
