Teledyne e2v
Monochrome, color and multispectral image capture
Teledyne e2v introduces the Tetra quad-linear CMOS sensor family, which is particularly suitable for food sorting, recycling, logistics, pick-and-place, document scanning and other machine vision applications.
© Teledyne e2v
The sensors are available with 2k resolution and a pixel size of 14 µm x 14 µm or with 4k resolution and a pixel size of 7 µm x 7 µm at a maximum line rate of 128 kHz. The monochrome models can be configured to output one, two or four lines, while the color models offer RGB and monochrome outputs. By using coated dichroic filters at wafer level, spectrally independent RGB and NIR output is also possible for multispectral imaging.
Based on a synchronized shutter design, the sensors offer low noise during image acquisition and a high dynamic range with true correlated double scanning (CDS), according to the supplier. Each channel has its own exposure control.
Teledyne Dalsa
Reliably sorted and packaged
Sorting food manually is time-consuming, strenuous and error-prone. It is therefore only logical to rely on automation with the support of image processing, as a look at two companies belonging to the Unilever Group shows.
Thermography
Teledyne takes over Flir Systems
The conglomerate Teledyne Technologies wants to acquire the sensor system manufacturer Flir Systems - as part of a cash and share transaction worth around 8 billion US dollars. The two companies signed an agreement to this effect on January 4, 2021.
