Vision Components
In the size of an image sensor module
Vision Components has launched an embedded vision system on the market that fits entirely on one circuit board.
Measuring just 22 mm x 23.5 mm, the VC picoSmart board camera contains all the components required for image processing: 1-megapixel CMOS sensor with global shutter, FPGA module, high-end FPU processor and memory. An interface board can be connected via the integrated FPC connector. This allows the Vision Components board camera to serve as a basis for the rapid development of cost-effective, application-specific and compact vision sensors.
The 'VCRT' operating system enables image processing in real time, for example for object detection, position control, barcode reading, web edge and fill level control.
