Excelitas Technologies
High resolution also for area sensors
Excelitas Technologies adds an area scan module to the accessories for the high-resolution machine vision lens 'Linos d.fine HR 2.4/128 3.33x'.
© Excelitas Technologies
In combination with the Linos d.fine HR Area Scan Module, the lens enables inspection with very large area sensors. The company thus offers a second, alternative equipment option for its inspection lens after the prism module, which enables coaxial illumination in line scan applications.
The lens with its 82 mm image circle achieves a resolution of up to 300 lp/mm in the object at a magnification of -3.33 in the wavelength range 400 to 750 nm. Equipped with the area scan module, it is particularly suitable for area scan cameras with resolutions of over 150 megapixels and the smallest pixel sizes of 3.5 µm. In addition, the lens has a very high light intensity with an aperture of 2.4. As it is virtually distortion-free, it is suitable for automatic inspection.
Teledyne Dalsa
Reliably sorted and packaged
Sorting food manually is time-consuming, strenuous and error-prone. It is therefore only logical to rely on automation with the support of image processing, as a look at two companies belonging to the Unilever Group shows.
MVTec
The 'eye of production'
Machine vision makes a significant contribution to the end-to-end automation and optimization of production chains. If artificial intelligence methods such as deep learning are used here, process efficiency can be further increased.
SVS-Vistek
One camera for VIS and NIR
The exo990, exo991 and fxo990 cameras from SVS-Vistek cover a wide wavelength range from the visible VIS to the invisible SWIR range and are as easy to use with the GenICam interface as normal industrial cameras.
