SVS-Vistek
Full 10GigE bandwidth
In the 'FXO' camera series, SVS-Vistek relies on the fourth-generation 'Pregius S' sensors from Sony and the 10GigE interface.
© SVS-Vistek
According to SVS-Vistek, the sensors deliver outstanding image quality with a dynamic range of around 70 dB. An intelligent frame buffer concept ensures a stable Ethernet connection with full 10GigE bandwidth. The Power-over-Ethernet module (PoE) allows the cameras to be operated with a single supply cable, which also provides the power supply in addition to the 10GigE data transmission. The 10GigE connection is made via a standardized GenTL interface and therefore offers flexibility in the choice of software for image evaluation. The multi-channel strobe controller integrated in the camera and the I/O module with the sequencer are also addressed via GenTL. The models are also available with a CoaXPress 12 interface for applications where more power is required. The camera series includes models with resolutions from 16.1 to 24.5 MP and frame rates from 30.1 to 45 fps.
Acceed
For edge computing applications
In 2020, Adlink sealed its collaboration with Nvidia as a Jetson Preferred Partner and has since developed various specialized controllers and systems for AI applications and machine learning. The all-in-one camera system 'Neon-2000-JT2' has also...
Rauscher
Precision in the large field of vision
Rauscher has six 'Basler boost' cameras with sensors from the 'XGS' series from ON Semiconductor. According to the supplier, the CoaXPress cameras are suitable for applications that require high resolutions and precision in a large field of view.
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
