ifm
Based on deep learning
The ifm mate digital assistance system from ifm supports workers with manual tasks in production or at packaging workstations.
© ifm
Using an optical 2D/3D camera, it identifies the worker's hands and thus recognizes whether a box has been reached into, for example. The central component of the system is hand recognition based on deep learning technology. The assistance system consists of a computer with a touch monitor, the software and an optical sensor that records both a 2D video image and a 3D image. Thanks to hand recognition in the 2D camera image, the worker assistance system from ifm does not require additional aids such as VR glasses or wrist trackers.
The work processes can be flexibly defined in the software. For example, it is possible to specify whether the sequence of steps should be predefined or whether they can be carried out in any order. The system then checks whether the work sequence has been carried out correctly and displays any deviations on the monitor. A combined visual and acoustic signal transmitter is available as an option, which alerts the worker to errors directly in the field of vision.
ifm
Innovation and quality
Measuring, controlling, regulating and evaluating - when it comes to pioneering automation and digitalization technology, the ifm group of companies is the ideal partner.
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
Deevio
End of manual visual inspection?
The widespread industrial use of artificial intelligence is still a long way off. Yet self-optimizing deep learning solutions are an important milestone on the way to the smart factory, which consists of AI-based production facilities and logistics...
Basler
AI platform for machine vision
Basler has announced a new AI platform for machine vision based on the artificial intelligence and machine learning (AI/ML) services from Amazon Web Services (AWS). It enables customers to seamlessly deploy AI-based applications.
