Schneider Electric
UPS systems up to 150 kW output
Schneider Electric is expanding its range of compact, three-phase UPS systems with double conversion technology: The Galaxy-VS series is available with system outputs of up to 150 kW and an external battery cabinet.
© Schneider Electric
Thanks to the extended power range, the series covers capacities from 20 to 150 kW. The double conversion mode achieves up to 97% efficiency, the patented 'ECONversion' mode up to 99%. In addition, the UPS backup time can be doubled through the use of lithium-ion batteries. Critical system components are built as modules with a fault-tolerant design, which, according to the manufacturer, enables internal redundancy with a reduced load and a short MTTR.
The UPS systems support integration into the cloud-based DCIM system 'EcoStruxure-IT'. This remote management platform enables secure, remote monitoring of UPS systems across multiple locations
Phoenix Contact
System availability ensured
Even if only one component fails, the entire machine or system can - in the worst case - come to a standstill, as their functions are usually closely interlinked. To prevent this worst-case scenario, every fault must be safely shut down.
