Sagittarius
Power supplies with power boost function
Lütze is expanding its range of 3-phase Compact power supplies with two versions with 120 W (5 A) and 240 W (10 A).
The two Compact power supplies from Lütze have an integrated power boost function to bridge large load peaks. They have a wide-range input and allow parallel operation with active load balancing. They also offer improved ease of servicing, as the power supplies have been specifically optimized for easy installation and maintenance. In addition to the tool-free push-in connection technology, both have defined connection terminals for precise assignment on circuit diagrams and in EPLAN macros.
There are QR codes on the front sides that link to relevant device documents. The remote function makes it possible to switch the power supplies on and off remotely and thus reduce energy consumption. Status data can be output via a status output. With their aluminum housing, the power supplies are protected against mechanical loads in accordance with IP20. The Compact power supplies have national and international approvals, including CE, UKCA, UL 61010-1 and UL 61010-2-201.
