Charging controls
Quelle: Phoenix Contact | Inka Krischke,
Integrated power supply
The EVCC Basic charging controllers from the 'EV Charge Control' series from Phoenix Contact have been specially developed for use in simple charging stations. All essential functions required for AC charging of an electric vehicle in accordance with IEC 61851-1 are implemented on the control board.
© Phoenix Contact
The integration of a power supply and an automatic unlocking function in the event of a power failure reduces the wiring effort and additional component costs. Configurable inputs and outputs increase the user's flexibility with regard to additional functions such as analog charging current control or monitoring of the charging contactor. The charging status display and device configuration can be carried out remotely on a computer system via an RS485 communication interface. The charging controller is available in four different versions and also as a printed circuit board or in a housing for top-hat rail mounting.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
