Bicker
Flexible system integration
The BE-DCEB10A DC inrush current limiter from Bicker Elektronik protects against high currents that occur when capacitive DC loads are switched on and can damage the power supply or trigger fuse elements.
© Bicker Electronics
With input voltages of 10 to 30 V(DC), the compact PCB module from Bicker limits the inrush current to approx. 12 A during the inrush torque. The maximum load current in rated operation is 10 A. According to the manufacturer, the inrush current limiter significantly increases the functional reliability and system availability of the application. Additional safety is provided by integrated overcurrent and short-circuit protection. Equipped with practical screw terminals and mounting holes, the FR4 board with a footprint of just 63.9 mm x 40.3 mm can be flexibly integrated and connected in a variety of different applications to save space.
