Bicker
Industrial mainboards reliably supplied
The DC161W fanless DC-ATX converter from Bicker Elektronik is suitable for mobile applications in 12 V or 24 V on-board power supplies as well as for industrial and medical embedded IPCs.
Precisely regulated +5 Vsb/ +3.3 V/ +5 V/ +/-12 V are available at the ATX output. The DC/DC converter from Bicker Elektronik with 93 % efficiency is equipped for 24/7 continuous operation in the temperature range from -20 to +70 °C. With a wide-range input of 6 to 36 V(DC), it ensures a stable power supply to the connected mainboard even in the event of major fluctuations in the supply voltage. Its cable management system enables the flexible use of customer-specific cable harness solutions. A suitable thermal pad (gap filler pad) is included in the scope of delivery for the thermal connection of the power components on the underside of the board. The DC/DC converter can be operated both in standard power supply mode and in automotive mode, for example for CarPCs.
