Rugged
Use in harsh environments
nVent has announced an expansion of the Schroff product portfolio with a robust enclosure family specifically designed to protect sensitive electronics in harsh environmental conditions.
© Rugged
The standard version of the IP-Pro Alu EMC enclosure already offers IP protection of IP65, which can be extended to IP67 if required. The die-cast aluminum housing is also EMC-protected and resistant to shock, vibration and corrosion. According to Schroff, the housing platform is available from stock in 15 different dimensions from 90 mm x 122 mm x 122 mm to 180 mm x 600 mm x 310 mm (HxWxD).
By using aluminum housings, conduction cooling ensures reliable passive heat dissipation through the housing itself.
The housing itself is designed for temperatures from -30 to +80 °C.
Rugged
Precise temperature maintenance
Varistar LHX+ from nVent Electric is a standardized modular cooling system with up to 10 kW cooling capacity for test and measurement applications. The temperature control accuracy of the system is specified as ±0.1 °C peak to peak.
Rittal
Fit for the outdoors
With the AX plastic enclosures, Rittal completes its compact enclosure range and replaces the previous KS series. Typical fields of application are waste water drinking water systems, photovoltaics and aggressive environments such as maritime...
Dold
Enclosed in accordance with standards
In order to turn an electronic assembly into a functional module for installation in the control cabinet, a suitable housing is essential. The requirements for this go beyond packaging and protection for the electronics. What needs to be considered...
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
