Phoenix Contact
Advertorial,
Tool-free cabling HEAVYCON Click-in
The click-in contact inserts from Phoenix Contact for HEAVYCON heavy-duty connectors increase the efficiency of cabling. The extremely easy and safe handling without tools saves a significant amount of time. Where previously screws were used, they are now simply plugged in.
When assembling cable harnesses in control cabinet construction and system cabling, the manual work steps have a significant impact on costs. This is why there is a high demand for
for products that make the assembly of heavy connectors quicker and easier.
© Phoenix Contact
HEAVYCON click-in contact inserts from Phoenix Contact offer completely screwless assembly for the first time and significantly reduce the assembly effort compared to all known solutions.
Conductors are connected using push-in technology. Rigid and pre-treated conductors are contacted in a shock- and vibration-proof manner by means of feather-light plugging. The protective conductor is also wired using push-in. Fitting the contact insert into the connector housing is then just a simple "click" - without any screws or tools.
Secure installation is confirmed by the audible and perceptible latching action. The force-fit connection of the contact insert to the connector housing is based on a wedge-shaped spring-loaded locking element that engages in an undercut in the housing wall. This undercut is present in all plastic and metal housings of the B-Series HEAVYCON EVO and HEAVYCON STA from Phoenix Contact.
© Phoenix Contact
When combined with the HEAVYCON EVO enclosure series, no screws are required at the cable outlet. The cable outlet can be mounted in either a straight or lateral direction using a bayonet lock. This time advantage makes it economical to assemble and wire complex systems at any location, even for small quantities and high variance.
Save significant time with tool-free installation and assembly throughout
HEAVYCON Click-in contact inserts from Phoenix Contact guarantee simple assembly and safe installation of your heavy-duty connectors. You do not need any tools for conductor connection or assembly in the connector housing. This is unique on the market!
Lapp
Asia strong, Europe weak
The Lapp Group achieved sales of 1.93 billion euros in the past 2025 financial year (October 1, 2024 to September 30, 2025). Driven by growth in Asia and America, the Stuttgart-based family-owned company is thus compensating for its decline in sales...
