Rittal
Simplified ordering and assembly
If enclosures are to be used as stand-alone solutions, individual enclosures such as the VX SE from Rittal offer various advantages over bayed enclosures.
© Rittal
In contrast to bayed enclosures with a frame and removable side panels, the single enclosure has a body made from a single piece of sheet steel or stainless steel. Moulded side panels including roof and fewer individual components significantly simplify and speed up ordering and assembly.
As the side panels and roof are already conductively connected to the frame, there is no need for separate earthing to the frame. Increased safety is guaranteed, as the lack of gaps between the sides, roof and frame, for example, prevents dirt from accumulating.
Even in its basic version, the 'VX SE' from Rittal has IP55 protection, IK10 impact protection, automatic potential equalization, high stability thanks to torsional rigidity and a load capacity of 1.5 t. For higher protection class requirements, the single enclosure is optionally available in an IP66 and NEMA 4/4x version. Integrated flange plates in the base make cable entry in the high-density enclosures particularly easy.
Rittal
Support arm with larger radius
Rittal offers height-adjustable support arm systems from the CP series with a longer support profile for loads of up to 15 kg in order to adjust operating terminals precisely to the height of the operator and their area of activity.
dtm group
Certified to IP54
The dtm group is expanding its solution portfolio to include modular data cabinets for harsh IT environments: The standard open STV40/45n floor-standing distributors and 40/45U server racks are also available as closed systems with sealed side...
Rittal
Fit for the outdoors
With the AX plastic enclosures, Rittal completes its compact enclosure range and replaces the previous KS series. Typical fields of application are waste water drinking water systems, photovoltaics and aggressive environments such as maritime...
Phoenix Contact
The 'security life cycle'
In the European Economic Area, the requirements of the Machinery Directive apply to manufacturers of machinery. Their specifications must be complied with before a machine is placed on the market. Many safety regulations must already be observed...
