Linear axes
Quelle: Rollon | Inka Krischke,
Seventh axis for robots
With the Rail System, Rollon offers a modular system of various heavy-duty linear axes and guides that can be used to add a seventh axis to robot applications.
© Rollon
The entire robot moves on a linear axis close to the floor. Small to medium-sized robots with a maximum dead weight of 2 tons can be moved. The linear axis is primarily constructed using 'Tecline' profiles from the supplier, prismatic roller or profile rail guides with rack and pinion drive. For example, the articulated robot can run parallel to a production line on the linear axis and carry out manipulations. It can also be expanded into a mobile feeder robot that serves several feed points for workpieces. Individual linear axes can be up to 12 m long; for longer ranges, several carriers can be butt-jointed.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
