D-Sub connector
Günter Herkommer,
Secure connection without special tools
Until now, the assembly of D-Sub connectors has often involved a great deal of effort or the use of special tools. A new solution based on a cage clamp connection promises significant time savings.
© Knorrtec
For more than 60 years, D-Sub connectors have ensured smooth data transmission on PCs and large production systems. However, assembly often goes less smoothly: the conditions under which connectors are to be soldered to cables, for example, are often anything but ideal. "Situations in which the specialist has to connect contact points overhead in a confined space and in poor light are not uncommon," notes Franz Knorr, owner of Knorrtec, in this context and adds: "If a wire is then soldered incorrectly, the repair work is correspondingly more time-consuming."
Crimping, on the other hand, is a far less complex method of attaching a D-Sub connector. However, the connectors usually have to be attached using expensive special tools, which are only worth buying if they are used regularly. Repair work can also become a lengthy undertaking. Last but not least, fixing with screw terminals is also time-consuming and involves risks: The screws can loosen over time and therefore need to be retightened regularly to avoid downtime.
Franz Knorr, Knorrtec: "The D-Sub connector requires no soldering or crimping and is designed for around 200 mating cycles."
© Knorrtec
In contrast, according to Franz Knorr, D-subs with a cage clamp connection can be installed relatively quickly and easily. Until now, however, the standard housings available did not have the right dimensions to accommodate such a connection. A shortcoming that prompted Knorrtec, at the request of a customer, to develop a special solution that allows the cable to be connected with cage clamp terminals. The locking method commonly used with D-Sub connectors using knurled screws is still guaranteed.
This connection technology makes it much easier to correct errors, as only the housing needs to be unscrewed and the cage clamp terminal opened. Even after the terminal has been opened and closed several times, it makes a secure connection. Screw terminals, on the other hand, offer less long-term reliability, as the cables to be connected consist of stranded copper wires and the flow behavior of the copper can lead to an increase in contact resistance and thus to a deterioration of the contacting.
Another advantage of the new solution is that the connector is only 16.6 mm high despite the cage clamp connection. In addition, the connectors can be installed housing to housing to save space and therefore offer a very efficient solution, for example when space is limited or when a large number of connectors need to be arranged. Knorrtec now manufactures the D-Sub in series in different variants. "The industrial-quality connector is designed for around 200 mating cycles. Only standard tools are required for assembly," says Knorr. Depending on the stress in the application, it can therefore last for a service life of around 10 to 15 years.
The D-Sub connector with cage clamp connection and screw lock is available in a 9-, 15- or 25-pin version as well as an HD version.
© Knorrtec
Industrial PCs can be equipped with the plug connector, as can PLC controllers or industrial printers. Even rarely used interfaces, such as special industrial interfaces, can be connected in this way. The energy transition also opens up new possibilities, as the Managing Director explains: "The new D-Sub is suitable for connecting CAN bus interfaces, which are used in wind turbines, for example; measurement technology is also a conceivable area of application."
The connector is available in a 9-, 15- or 25-pin version with dimensions of 31 mm × 60 mm × 16.6 mm or 39.5 mm × 75 mm × 16.6 mm or 53 mm × 75 mm × 16.6 mm. The housing is available as a pure plastic version or as a metallized version for EMC-critical applications. The latter is coated with a nickel layer. This ensures good conductivity so that the D-Sub is resistant to interference.
Connectable cables can have a maximum wire cross-section of 0.5 mm² and a maximum sheath diameter of 10.5 mm. The plug connection with protection class IP20 can be used at temperatures from -20 to +85 °C. The dielectric strength is 100 V, the current carrying capacity is 1.2 A with a test voltage of 1 kV/mm and clearances and creepage distances of 0.5 mm. There are also some variants as three-row HD connectors.
Lapp
Asia strong, Europe weak
The Lapp Group achieved sales of 1.93 billion euros in the past 2025 financial year (October 1, 2024 to September 30, 2025). Driven by growth in Asia and America, the Stuttgart-based family-owned company is thus compensating for its decline in sales...
