Lütze
PVC control cables for industrial applications
Lütze is expanding its cable and wire portfolio to include PVC control cables for fixed installation and flexible applications in industrial environments.
The control cables are available in unshielded and shielded versions and cover a wide voltage range from 300/500 V to 450/750 V and up to 0.6/1 kV. They have fine-stranded conductors of strand class 5 and are available with colored or numbered cores, depending on the series. The unshielded versions are available with a gray sheath (RAL 7001) or black sheath (RAL 9005). The shielded cables with good EMC properties are available in gray (RAL 7001), transparent or black (RAL 9005). Black sheath versions are UV-resistant and therefore suitable for outdoor installation. The shielded versions guarantee reliable electromagnetic compatibility and are particularly suitable for use in industrial control and automation environments. The structure and technical properties of the cables comply with the usual market standards.
