Gett appliance technology
Push-button with optical detection
The 'KO28010' optical pushbutton from Gett Gerätetechnik is designed as a built-in component, like a classic mechanical pushbutton with a bore diameter of 22.3 mm and an outer diameter of the button head of 30 mm.
© Gett appliance technology
The sensor technology of the optical push-button is designed as a pure proximity sensor. The maximum detection of an approach by the sensor is 150 mm. From this distance, events can be reliably defined using threshold values. The push-button from Gett Gerätetechnik offers three switching states as standard: stand-by, approach and triggering. The first two phases are indicated by the LEDs lighting up blue. The actual switching process takes place 20 mm in front of the surface when the light changes to green. To prevent unintentional switching - for example by walking past or accidentally touching - the switch-on time of the push-button is 100 ms; the same applies to the switch-off delay. The distance of the threshold values and switching times can be defined according to customer requirements.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
