Rugged
Precise temperature maintenance
Varistar LHX+ from nVent Electric is a standardized modular cooling system with up to 10 kW cooling capacity for test and measurement applications. The temperature control accuracy of the system is specified as ±0.1 °C peak to peak.
Varistar LHX+ from nVent Electric (Schroff)
© Rugged
The cooling system from Schroff with scalable climate management requires a footprint of 600 mm x 800 mm. The electronics cabinet achieves an air flow rate of 1000 to 1800 m3/h. Depending on requirements, the cooling capacity can be increased during operation without adapting the infrastructure inside the cabinet. For a higher cooling capacity, a double-fan cooling unit with a cooling capacity of 10 kW can be interchanged with the single-fan cooling unit, which supports a cooling capacity of 5 kW.
Temperature control is realized via a modular control unit with the option of remote monitoring and remote control. Ethernet, SNMP, Modbus, TCP and web interface are available for remote applications. The temperature can be controlled via a door-mounted terminal with display and keypad as well as remotely via Ethernet access and web interface.
Rugged
Use in harsh environments
nVent has announced an expansion of the Schroff product portfolio with a robust enclosure family specifically designed to protect sensitive electronics in harsh environmental conditions.
Rittal
Megawatt cooling developed for AI
Rittal has developed a cooling solution that delivers over 1 MW of cooling power and paves the way for artificial intelligence. This is because the demand for computing power is growing so rapidly that a new level of scaling, cooling, power...
Rittal
Dialog and application center opened
The energy transition requires the rapid conversion and expansion of the electricity infrastructure, which increases the demand for low-voltage switchgear. The Rittal Application Center offers customers support in automating their processes when...
Rittal
New Chief Business Units Officer
Ulrich Engenhardt has been the new Chief Business Units Officer (CBO) on the Rittal Management Board since June 1, 2023. The 49-year-old is responsible for the global expansion of the Industry, IT, Energy & Power, Cooling and Service business...
Rittal
Support arm with larger radius
Rittal offers height-adjustable support arm systems from the CP series with a longer support profile for loads of up to 15 kg in order to adjust operating terminals precisely to the height of the operator and their area of activity.
