Lapp
Multiple introductions extended
Lapp is expanding its portfolio of 'Skintop Multi' multiple entries with two further sizes for the round version of the 'Skintop Multi-M' series.
The 'Skintop Multi' multiple introduction from Lapp
© Lapp
Cables are pushed through the elastic gel insert and are securely positioned in place thanks to the static friction on the cable sheath and sealed in accordance with IP68 protection. The funnel-step geometry of the individual entry points enables the maximum clamping ranges to be increased with up to 4 mm variance per cable diameter. Unused entry points remain securely closed and sealed thanks to the elastic gel technology. The multiple entry is mounted on the housing by screwing it in or fixing it with a locknut. In addition to the gel insert, it consists of a polycarbonate frame.
UL certification for the North American market is available in accordance with UL 50, UL 50E, CSA C22.2 and UL 508A for industrial system controls. In addition to the previous round multiple entries for a maximum of twelve, 18 or 30 cables, which can be inserted into one housing at the same time, Lapp now offers variants for four or eight cables.
Lapp
A guard for the data line
In the smart factory, predictive maintenance is an important tool for avoiding unplanned machine downtimes. In Ethernet-based networks, attention should always be paid to the data line.
Lapp
Guard for the data line
Predictive maintenance helps to minimize unplanned machine downtimes. Lapp is now presenting a solution that monitors the service life of failure-prone data lines in Ethernet-based automation technology networks.
Lapp
Sales fall by 7.7
Despite the global economic slowdown and the COVID-19 pandemic, Lapp performed relatively robustly in the 2019/2020 financial year (October 1 to September 30). However, sales decreased by 7.7% to € 1128 million.
